CBuserIndia Posted December 14, 2016 Share Posted December 14, 2016 Hello I am using Chief Architecture x8 Interior version. I want to find out if I can create Block of a simple room. Room has 4 walls, door, window. As soon as I select wall, I don't get "Add to library option" If above is not possible, is there any work-around ? Problem, I am trying to solve is - I want to start a project with a room which has walls, doors, window, & may be few other objects which will get re-used every-time. I want to drag & drop this room object & then I will customize this room block as per requirement. Thanks Nitin Link to comment Share on other sites More sharing options...
johnny Posted December 14, 2016 Share Posted December 14, 2016 Not possible to block those items...chief doesn't allow blocks of walls and other things. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 14, 2016 Share Posted December 14, 2016 Save the whole plan file as a template plan. It will be there every time you open the template ready for modification. Link to comment Share on other sites More sharing options...
