Material listlist not calculating correctly
finelinerick
You precisely administer 3D objects, walls, layers, every thing in the model. Your virtual model has to reflect how you intend to build in the field in every detail. To the degree it does not your Materials List will be also found to be to the same degree inaccurate. The Materials List just tabulates how you created the .plan file and NOTHING ELSE! Only you can make the .plan file perfect and when actually perfect you then and only then get an accurate ML.
  • Downvote 1
yes the 100 " x 8"  foundation walls which calculate correctly and also the 4" slab which calculates correctly if you have time build a simple plan and build a foundation with piers and grade beam and you will see what I am talking about . maybe the program is thinking its a solid continuous footing
