AutoCAD Lineweights / .DWG import
amddrafting
So whatever happened to the default AutoCAD Layerset that used to convert standard layers set to the AIA / AutoCAD standard?
Also, I'm in a bit of a pickle.  I had a client send me a .dwg and when I import them and check "import all attributes of lines" (paraphrased) it does not import the lineweights.  It defaults them all to 1?  What gives?
