Sign in to follow this
amddrafting
AutoCAD Lineweights / .DWG import
So whatever happened to the default AutoCAD Layerset that used to convert standard layers set to the AIA / AutoCAD standard?
Also, I'm in a bit of a pickle.  I had a client send me a .dwg and when I import them and check "import all attributes of lines" (paraphrased) it does not import the lineweights.  It defaults them all to 1?  What gives?
Yes,  I ended up downloading AutoCAD LT demo to work on this project.  And all lines do in fact have assigned lineweights.  When importing they all covert to 1 in Chief.
Are the line weights by layer, or by object in the original dwg?
That could make a difference.
    29120
    Amanla
    Amanla
