Looking for help: convert PDF project to CA
davidbakh, in Seeking Services
Member Statistics
Similar Content
By KatieFuller
Help! When generating a 3D view, my view is in black and white unless zooming in very close. I tried to reset back to all of the default settings as well as resetting to defaults for my preferences. Nothing seems to help. My previous projects still appear as they should, but any new projects I try to create have the same black and white issue. I've attached a screenshot of the issue. Does any one know how to fix this? Any help would be greatly appreciated.
By Noremac
Hello there!
I'm new to chief as of a few weeks ago. I'm really loving how in-depth you can get with it. Hopefully this isn't to much of a newbie question that is easily answered somewhere else but I have seen anything on it. I'm trying to attach a shed roof to a gable. I have a feeling this is something similar to a porch roof, but after messing with it for a few hours I cant figure it out.
This is what I'm go
Here is where I'm at.
I've attached my plan if that helps!
I'm using x12
Thanks!
-Cam
Piper_3rd Round 2_4_2021.plan
By Sunnyfields
I am trying to do a presentation plan and am using a top down orthographic view with watercolor and overlaid lines. I can't get the resolution I need exporting an image from CA so I have sent the view to Layout as a live view. We also tried it as an image. The problem is that every time I try to create a PDF two walls disappear. The view box is large enough, so I haven't cropped the view, I've had our veteran Chief guy look at it, and we're stumped. Here is the result:
Here is the view in Layout:
And Here is the print preview:
Has this happened to anyone else? I have tried outputting this about a dozen times and the same two walls are cut off every time.
I am running CA Premier X12 on a Dell with these bells and whistles. I also have Bluebeam Revu as my PDF print driver in addition to the "Export" function in CA. I have tried to print and to export with the same result . Any help would be appreciated.
By Quickchevys
So I learned this software(somewhat) and designed a house for my family about 6 years ago and the plan is now in motion to build the house. I have since forgot how to do all of the editing of the house and need a few tweaks done as well as the roof properly done since I never was able to understand how to get that part right. I also know that some walls, floors, and stairs were kind of just manipulated to be close enough to look ok in the camera view. So I would like someone that has more experience with the program to kind of go through my drawings and correct the things that need to be corrected and also get files for blueprints ready. I never could figure out that part either.
