x8 Printing Help
REMDES
Not sure if it will make a difference for you, but is the roof and fascia supposed to extend that far down? Right now it is lower than your front door. If you post plan and even your layout it might be easier to solve. Just make sure the are not open in Chief when you try and upload them.
Just me Jerry,
  The door and window set in from the exterior wall about 2' so their covered by the sloping roof.  Plan and layout attached.
Chopsaw when I send to layout the elevations are  grossly pixelated I do some annotation in layout so I need a clear image.  I just  down loaded X8  2 weeks ago after using X6 for a long time and was dismayed when I sent the elevations to layout.   They do print clearer (except for the shading) but I still need to have a better elevation in layout.
Thanks
Jerry
Remodeling Designs
X8
4013A SCH4 11.7 X8.plan
RD 18X24 4013.layout
Jerry,  To get what you are used to in X6 sent to layout as "Plot Lines" and update manually.  If you like you can open the layout box and switch to live view before printing for all the new X8 features.
Did the Shadows off, work or should I take a look at your plan?
Jerry, When I updated your layout elevations the coloured shading disappears so I am not sure what was causing the problem. Your new upper dormers are not quite attached to the main roof. The "Join Roof Planes" tool should work fine for this job post-4797-0-34410700-1479092391.jpg
