Sign in to follow this
Chiefusermickey
Auto Exterior Dimensions Overwrite previous auto dim
Why is when I use auto exterior dimensions tool it overwrites previous auto exterior dimension instead of updating them or deleting?  Some dimensions will have multiple copies of the same dimension line pasted on top of one another.  Others will become garbled up and not readable because of old auto dimensions that were not deleted or updated.  File attached
Willow 1600.plan
If you have not shifted any dimension strings you don't see this, but it is how CA works. I know it is a PITA as you often have to move some of the strings, even with the defaults set up correctly
I leave Auto Refresh Dimensions toggled on in my template plan so that as so as I draw an enclosed space or edit the floor plan, the auto exterior dimensions are generated and updated (not overwritten) automatically.
No need to even select Auto Exterior Dimensions - it just happens.
    27873
    cbling
    cbling
  • Similar Content
    • By 152431
      Noticing a difference from Home Designer when I switched to Chief that I am wondering if it is a setting issue?
      In Home Designer, when I hovered over a footing (say a deck footing), the program indicated where the center of the footing was.  I am not seeing this in Chief.  Anyone know what I am missing?
      Thanks
      maximus
    • By mslewis620
      For some reason auto ext dim has started acting up. Checked the usual suspects and for the life of me can't find the source of the problem.
      When I use auto exterior only part of the floor plan is dimensioned. I've tried deleting all dimensions and starting over but nothing works.
      X6 user
