MBagshaw Posted November 2, 2016 Share Posted November 2, 2016 Hi folks, I have struck an odd problem I've never experienced before displaying imported materials correctly using raytrace. I imported a JPEG containing the attachedimage of white marble, and while it shows up fine in all other views (3D camera, for example), in raytrace it shows up as a red/pink colour without any of the marble detail (see attached). In this example I am using the material on a solid that was created using poly line solid then converted to a solid. I have imported lots of other materials including the timber in the background of the attached screenshot and they have always displayed correctly in raytrace until now. It doesn't seem to make any difference how long I leave the raytrace to run (this one was produced after about 90 passes – the advantages of a fast processor!). Any ideas? Cheers, Link to comment Share on other sites More sharing options...
rlackore Posted November 2, 2016 Share Posted November 2, 2016 Can you attach the plan (or at least the material definition as a library item)? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 2, 2016 Share Posted November 2, 2016 These two posts seem eerily similar : https://chieftalk.chiefarchitect.com/index.php?/topic/11563-very-weird-ray-trace/?hl=%2Bray+%2Btrace Since you have the JPEG you may be able to recreate and define the material within chief to fix the problem. Link to comment Share on other sites More sharing options...
jcaffee Posted November 3, 2016 Share Posted November 3, 2016 Is the fireplace something you've imported as well? Looks like one of those Sketchup double-sided polygone SNAFUs Link to comment Share on other sites More sharing options...
MBagshaw Posted November 3, 2016 Author Share Posted November 3, 2016 Hi Jon, The fireplace itself (i.e. the flame, the box and the stainless steel frame around it) was imported from sketch up, but the whole chimney and the marble feature were created as poly line solids in CA then converted into solids. I tried to attach the plan itself But it is too large (90 MB). Can anybody give me any guidance on what I should be looking for in the plan that is making the file so big? That would also account for the fact that is now taking forever to rebuild the 3D perspectives. Cheers, Link to comment Share on other sites More sharing options...
Chopsaw Posted November 3, 2016 Share Posted November 3, 2016 Hi Mark, Give this a try, it seems to work fine for me. If your original .jpg is more that 96 dpi you could make your own library material with higher resolution. Marbel For Mark.calibz Link to comment Share on other sites More sharing options...
MBagshaw Posted November 3, 2016 Author Share Posted November 3, 2016 Hi Chopsaw, Thanks for taking the time to do that. Whatever you did to my image, you fixed it so it now works perfectly in my plan. What exactly did you do to make it work? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 3, 2016 Share Posted November 3, 2016 I did not expect it to work perfectly as there are a lot of custom settings you can tweak for Raytracing but I did get rid of that awful purple mess. Right click on your Library User Catalog and that will bring up the "Define Material" Dialogue (The Tea Party). Go to the Texture tab and give it a name but don't spell it wrong like I did. Browse to where you have that .JPG file that you posted. Set it to "Stretch to Fit" and anything else you would like to play with in Properties and you are all set to put that in your Library when you say OK. And you can also do a quick Ray Trace test right in the DBX. Link to comment Share on other sites More sharing options...
limitless8 Posted November 12, 2016 Share Posted November 12, 2016 I guess I'm a little too late, I have the exact same picture for a marble texture in my custom library and never had issues with it, as much as I like the chief library I tend to download images and create my own. Link to comment Share on other sites More sharing options...
