Furred Basement Walls - baseboard missing
SNestor
Wondering why the baseboard...which is part of the "room" specification does not move out and attach itself to the "furred wall" surface.  I experimented with a simple plan with furred basement walls...and the base molding did move from the surface of the foundation wall to the surface of the "furred wall"...but it doesn't in the attached plan.  So...obviously I've done something.
I know I could easily attach base with a molding polyline...but, I'm just curious as to why it's not working...and what I've done wrong.
I've attached the plan...
Thanks!
7050 Plan.plan
Steve, change furring walls to split framing, then baseboard works.
Yea...that works, but it also creates a "room definition" between the back of the furred wall and the foundation wall.  I was trying to avoid that...
Maybe there isn't a way to avoid this?
I create a Room Molding Polyline, and drag it into the room.
Yep...I know I can do that...and actually, I've already done it.  Just wondered if there was some issue with my plan or some specification that caused the base molding not to attach to the "furred wall".
