olyconstruction Posted October 31, 2016 Share Posted October 31, 2016 Hi Chiefs, I am not sure what is going on here. It seems that recently when I export a view to layout I get this message (attached) saying that the view now references the "Layout Set" in my plan. I never created this Layout Set, and CA is making a new copy of that set for every view I export (I think I am at Layout Set 7 now). Does anyone know why this could be happening and what I can do to get it to stop? Your help is greatly appreciated, so thank you! AB Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted October 31, 2016 Solution Share Posted October 31, 2016 When you click Send To Layout there is an option to "Make Copy Of Active Layer Set". Uncheck that option. I personally like the feature but a lot of people don't. 1 Link to comment Share on other sites More sharing options...
olyconstruction Posted October 31, 2016 Author Share Posted October 31, 2016 Michael, What are the advantages of having it on? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 31, 2016 Share Posted October 31, 2016 I like it because my layout requirements are typically not very consistent from one to the next and neither are the views I send there. Create copy allows me to quickly and easily modify layer display on-the-fly on a view by view basis without having to keep track of how it will affect other views. If I want a handful of views to use the same layer set it's easy enough to change the name of one of the copies and use that instead either when sending to layout or by simply switching the layer set of any given view. I guess I just like the freedom. My style of drawing is just a lot more freestyle because my layout needs vary greatly from one job or task to the next. If you're making heavy use of the S.A.M. or a template method that re-uses both a plan and layout than Make Copy may not be quite as useful. I think it's real strengths come into play when creating layouts as you go...or maybe if you're using only the layout or only the plan as a template, but probably not both. Link to comment Share on other sites More sharing options...
olyconstruction Posted October 31, 2016 Author Share Posted October 31, 2016 That is good to know, I will keep that in mind for future projects where I might need to independently edit a particular view. Thanks for the help! AB Link to comment Share on other sites More sharing options...
lbuttery Posted October 31, 2016 Share Posted October 31, 2016 I think Michael is the only one using this "feature" back in ver 10 I had a client who was using it and it caused me no end of grief mainly because I didn't even know about it - nor did the client when I got the plan there were 20+ copies of everything after working for some time and making changes I would find out that those changes appeared in some views and not others client starts hollering "I thought you made that change" I'm hollering back "I did" once I realized what was going on I got rid of all those "copies" and have avoided them ever since If you are still interested work with Michael to understand how they work, or .... Lew Link to comment Share on other sites More sharing options...
