manuel_songokuh Posted June 4, 2014 Share Posted June 4, 2014 hello i want to create the wall inclines (70° of angle, for normal wall is 90 angle)? i use chief architect premier x6. thank you Link to comment Share on other sites More sharing options...
BryceEngstrom Posted June 4, 2014 Share Posted June 4, 2014 Not really possible in Chief, unfortunately. You will have to make use of roof planes, or use invisible walls to create "spaces" and custom model the walls but they won't act as "walls" per se in Chief. This is one of the main shortcomings of Chief, although canted walls constitute a pretty small fraction of the built environment. 1 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 4, 2014 Share Posted June 4, 2014 Do you want the wall leaning over at 70 degs? or do you want the top of the Wall raked at 70 deg. ? Leaning walls aren't really doable as Bryce mentioned as far as I know. M. Link to comment Share on other sites More sharing options...
GeneDavis Posted June 4, 2014 Share Posted June 4, 2014 I have achieved the look of a battered wall (battered = angled out at bottom) using straight walls and custom moldings. Having seen battered walls built, that is pretty much how they are done. A straight wall has structure hung to its outside that boosts the bottom out, tapering to less at top. When the wall must have door and window openings, you need to be really creative. Polyline solids can be used to do the over and under fills. Link to comment Share on other sites More sharing options...
