How Does Inclines For Wall?
manuel_songokuh
Not really possible in Chief, unfortunately.  You will have to make use of roof planes, or use invisible walls to create "spaces" and custom model the walls but they won't act as "walls" per se in Chief.  This is one of the main shortcomings of Chief, although canted walls constitute a pretty small fraction of the built environment.
  • Downvote 1
I have achieved the look of a battered wall (battered = angled out at bottom) using straight walls and custom moldings.  Having seen battered walls built, that is pretty much how they are done.  A straight wall has structure hung to its outside that boosts the bottom out, tapering to less at top.
When the wall must have door and window openings, you need to be really creative.  Polyline solids can be used to do the over and under fills.
