DBearss Posted October 25, 2016 Share Posted October 25, 2016 I have my dimension number style to display as decimal feet however the dimensions are showing as feet with decimal inches. How do I get my site dimensions to display in decimal feet? Link to comment Share on other sites More sharing options...
glennw Posted October 25, 2016 Share Posted October 25, 2016 The settings in that dbx (Dialog Number/Angle Style) only applies to how measurements display in dbx's - not the dimensions themselves. In your case, you need to change the defaults for the "SITE Dimension Defaults". Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 25, 2016 Share Posted October 25, 2016 Set it up in the Dimension Defaults Link to comment Share on other sites More sharing options...
DBearss Posted October 25, 2016 Author Share Posted October 25, 2016 Sorry, Was away. Thanks for helping with this but my frustration continues. Dimension defaults are set up for decimals but am still getting feet and decimal inches. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 25, 2016 Share Posted October 25, 2016 Take a look at the pic I posted. The Primary Format Units need to be set to ' Then you also need to make sure that the Active Defaults are set to use that Default (whatever Dimension Default you want) You will also need to open the existing dimensions and set them to use your new Default. Any new dimensions should automatically match the new Default. Link to comment Share on other sites More sharing options...
DBearss Posted October 25, 2016 Author Share Posted October 25, 2016 Joseph, Thanks so much. Such a simple thing. Link to comment Share on other sites More sharing options...
