Designer100 Posted October 16, 2016 Share Posted October 16, 2016 I use Chief x8. A interior designer friend is new to home designer pro. She might want me to do some renderings and drafting for her in Home designer Pro. Will it be easy to help her since I know Chief x8. Is working in each similar. Newell newell.Cheatheam@gmail.com Link to comment Share on other sites More sharing options...
chief58 Posted October 16, 2016 Share Posted October 16, 2016 Check with Chief tomorrow, I am doing a project with someone that uses home designer pro and I have to use chief X7 to that we can go back and forth looking at plans and making revision, not sure if Chief has upgrade hd pro so that it works with x8 yet but they will know which will work for you it will all depend on what version of hd pro they have Link to comment Share on other sites More sharing options...
Northriver Posted October 16, 2016 Share Posted October 16, 2016 Newell, The interface looks the same. Click on the blue door at the top of the forum screen where you see the Facebook and YouTube Icons. Link to comment Share on other sites More sharing options...
lbuttery Posted October 17, 2016 Share Posted October 17, 2016 there is an edit flag that has to be set in Chief or the plan will be read only if you use any Premier features that PRO doesn't have that feature/area will be read only plan sharing can work but there are considerations as Ray stated the two have to be on the same version level to share Lew Link to comment Share on other sites More sharing options...
