Sign in to follow this
hannajonesdesign
Adding a basement
I have built the basement, main floor and 2nd floor but it appears as if the basement is my main level. How do I change my floors around so there are only 2 mains levels with a basement?
Thanks!
Some of us put the Foundation on Level 0, Basement on Level 1, First Floor on Level 2, Second Floor on Level 3, etc.  This is my preference for a finished Basement situation - especially for a Walk-Out
Others use Level 0 for the Foundation and the Basement, First Floor on Level 1, Second Floor on Level 2.  I think that can complicate things.
For some reason my roof isn't working correctly having the basement set as level 1, is there some way to change that?
Thank you!
The only way we're going to be able to help is if you post the plan.  BTW, what version are you using?
It's premier x7. How can I post the plan here?
Click on "More Reply Options", Browse to your Plan (Make sure it's not open), Open, then "Attach This File".
Close file, zip, and attach.
Or save to Dropbox and give us the DB link.
Hanna,
You will need to define a Terrain Perimeter and set the Elevation in order to get the Foundation to build properly.You will need to manually create the Foundation under the extended areas at the First Floor.  You also need to set the Foundation Type correctly and change the Basement Exterior Wall Type to Concrete or CMU.
Other wise I don't see a problem.
The Terrain elevation is the key.  Create it on Level 2 and set the elevation to about -8.5'
Simple answer is to just use a Rich Text Box placed on a unique layer.
Better yet, change the Label of the Layout Box when you send the Plan to Layout.
There are ways to use macros to get the Floor Number and adjust it based on the Level.  I could provide you with a couple of macros to do it.
Thank you! one last question (I think), how can I now call the basement level 0 and the main floor 1?
You could copy and paste using Edit Area. Cut level 1, go to level 0, Paste Hold Position. Do that for each level. Delete the upper level that now has nothing on it.
    27475
    slickrick1530
    slickrick1530
  • Similar Content
    • By SamanthaSkidmore
      I'm not sure when this happened or how it happened but my ceiling isn't meeting the wall in the basement.  The separation is from the garage.  I created a brand new plan to make sure my heights all matched up correctly and they do.  Can you tell by looking at my screenshots what might be happening or what I need to do to fix it?  Photo on the left is the wall/ceiling in the basement.  The photo on the right is from the garage.
      Thanks so much!
    • By ramseyatelier
      Hi,
      I'm relatively new to the program, I have done a few plans, but still getting used to everything.  I am working in X10 Premier software.
      I am having an issue with floor levels.  When I divide up a space with interior walls or room dividers, and want to make a adjacent room "sunken" with a negative floor elevation, the program is changing the floor of all the surrounding rooms too, not just the room that (is section off my walls or divider) I want at the lower elevation level.  Is there something I am missing here?  I have done this in prior plans, and never had this issue.  Maybe a gliche? Any info would be helpful.
      Thank you
      Stacey
    • By JbeckWY
      My client decided that instead of a full 2 story he would like to do a 1 1/2. Is there any way  I can drop the roof without having to delete all roof planes and building again? I have multiple manual roof planes and do not want to lose those.
    • By decorators3
      Hi
      I have Chief Architect premier 10.  I am trying to build a 4 story building but can't get past the 2nd floor.  I created the first floor and added the second floor based on the first floor plan but when I treid to add the next 2 levels nothing happens.. any help appreciated
    • By Renerabbitt
      feel free to scale and blend with texture. enjoy!
      American Oak stock and scaled/stained, AMERICAN OAK PLANK.calibz:
      knotty oak is high res. download from my cloud,https://1drv.ms/u/s!ArIPOe8v1Srkh8cxdtBNn8hF-Ja6OA :
      stock:scaled and stained:
