Sumnerbc Posted October 11, 2016 Share Posted October 11, 2016 I am working with a client of mine and they want to restore a downtown building. They have this historic moulding and I am wondering on how to do this in Chief Architect. See picture. Link to comment Share on other sites More sharing options...
johnny Posted October 12, 2016 Share Posted October 12, 2016 I would layer up 3D modelings and polysolids. If you have SSA there are some videos on this. Link to comment Share on other sites More sharing options...
Solution MarkMc Posted October 12, 2016 Solution Share Posted October 12, 2016 Might make a "molding symbols" , as opposed to "molding profile". Attached image uses both. Would still need a symbol for the ends and as JC pointed out elsewhere seperate millwork symbols to use as treatments on the windows. I put appliques on the front here. I would advise against that, will slog the system down. Just use a picture or simple graphic where needed. This was made from corbels found in the library-about 15 minutes-didn't worry about much accuracy, but you get the idea. 1 Link to comment Share on other sites More sharing options...
javatom Posted October 12, 2016 Share Posted October 12, 2016 Mark is spot on with the suggestion to use items from the library and call it close enough. Link to comment Share on other sites More sharing options...
Sumnerbc Posted October 12, 2016 Author Share Posted October 12, 2016 Thanks everyone for the suggestions. I have it figured out now Link to comment Share on other sites More sharing options...
