Framing - Build Roof/Floor Truss
ACADuser
Alan,
Your problem is that the material you're using for your floor structure (Pine 1) is not a Framing material.  There are a few ways you could change this, but here's one...
Open your Floor Structure Definition dbx, select that Pine 1 layer, click Select Material, click Plan Materials, click Edit, and then change the Material Type from "Area" to "Framing".  Then probably set your Floor Structure type to "Lumber" (although that is not necessary to get your trusses working).
