Is There Any Way To Change All Roof Overhangs After Auto Built?
HumbleChief
Edit the overhang settings then rebuild the auto roofs.
Unless you've fiddled with them manually and want to retain that. Then you will have to manually edit the overhangs.
Thanks Kevin, Not sure why I thought I could 'select all roof planes' and change the overhangs but ended up rebuilding roofs as there was little manual work to do.
I would love to see a way to change the overhang length universally without auto rebuilding.  I work on complicated roofs that auto only goes so far and then there is lots of manual work, so auto rebuild isn't an option if we decide to change to a different overhang length.
+1
