JJohnson Posted September 30, 2016 Share Posted September 30, 2016 I cannot seem to make an auto dormer place on the roof that the arrow is pointing to. The other one took time but finally placed. Have tried everything I can think of. Using Auto Floating Dormer Tool, Shed Roof Style Help Wanted ! Thanks, Portico Dormer Added.planFetching info... Link to comment Share on other sites More sharing options...
DavidJames Posted September 30, 2016 Share Posted September 30, 2016 Like this? Portico Dormer Added R1.planFetching info... Link to comment Share on other sites More sharing options...
Chopsaw Posted September 30, 2016 Share Posted September 30, 2016 JJ, Not sure I have ever even used an auto dormer before or at least that I can remember but got this first try just with copy and paste. Dumb luck I am sure. Is this what you are looking for? Link to comment Share on other sites More sharing options...
Solution jscussel Posted September 30, 2016 Solution Share Posted September 30, 2016 Jere, The Dormer needs to fit within the roof plane or it won't place. Go to the Default Settings> Dormer and lower the wall height to 48" and it will place. Link to comment Share on other sites More sharing options...
JJohnson Posted September 30, 2016 Author Share Posted September 30, 2016 On 9/30/2016 at 7:16 PM, jscussel said: Jere, The Dormer needs to fit within the roof plane or it won't place. Go to the Default Settings> Dormer and lower the wall height to 48" and it will place. That was it, wall could not be higher than roof rise I think. Looks like wall height adjustment is key to placing AND resizing these stubborn little guys Thanks ! Link to comment Share on other sites More sharing options...
JJohnson Posted September 30, 2016 Author Share Posted September 30, 2016 On 9/30/2016 at 7:14 PM, Chopsaw said: JJ, Not sure I have ever even used an auto dormer before or at least that I can remember but got this first try just with copy and paste. Dumb luck I am sure. Is this what you are looking for? Man I tried and tried, you are just plain lucky !! Link to comment Share on other sites More sharing options...
JJohnson Posted September 30, 2016 Author Share Posted September 30, 2016 On 9/30/2016 at 7:14 PM, Chopsaw said: JJ, Not sure I have ever even used an auto dormer before or at least that I can remember but got this first try just with copy and paste. Dumb luck I am sure. Is this what you are looking for? Did you do anything special, but yes that's what I needed? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 30, 2016 Share Posted September 30, 2016 On 9/30/2016 at 8:44 PM, JJohnson said: Did you do anything special, but yes that's what I needed? No nothing special just select CTRL + C and point then CTRL + V and click. Literally as Scott would say 2.3978 seconds. If it does not work for you plan is available. Link to comment Share on other sites More sharing options...
