ladycoralie Posted September 28, 2016 Share Posted September 28, 2016 Hi. I am having trouble generating a stairwell up to the 2nd floor over the garage. I have a railing suspended in mid air (attached picture) and the stairwell won't generate. I can't figure out what I'm doing wrong, but I bet it is something simple. I'm also having trouble with the wall not generating properly where you can see the icf sticking out, and there is a gap between the ceiling and the roof. Any help will be much appreciated. Cheers and thanks. Coralie Barn Copy.plan Link to comment Share on other sites More sharing options...
Greg_NY61 Posted September 28, 2016 Share Posted September 28, 2016 Is this what you trying to do? Barn Copy 1.plan Link to comment Share on other sites More sharing options...
ladycoralie Posted September 29, 2016 Author Share Posted September 29, 2016 Sorry Greg, but that's not it. I've attached the pic from it. I still can't get through to the top floor as there is only a little gap to get through, and the 2nd floor is over the garage. I've also got a gap in the walls. thanks though. Link to comment Share on other sites More sharing options...
ladycoralie Posted September 29, 2016 Author Share Posted September 29, 2016 I have tried creating the 2nd floor room where the stairs start as an open below, but I still end up with the same result. I also have this gap in the wall and one at the ceiling. I'm not sure what to do next to fix this. Link to comment Share on other sites More sharing options...
Solution DavidJames Posted September 29, 2016 Solution Share Posted September 29, 2016 I'm not sure if this is what you're trying to achieve, but take a look at the attachment (I've also made some adjustments for clarity)Also, it seems the reason you're stairwell wasn't generating was because you had an invisible wall near the top of the stairs for some reason(?). Delete that and the railings and try rebuilding. Barn Copy - R1.plan Link to comment Share on other sites More sharing options...
ladycoralie Posted September 29, 2016 Author Share Posted September 29, 2016 Hi and thanks. I got it. I didn't realise I had an invisible wall up there. Deleted that, but also took out the floating balcony and after rebuilding all the walls around it and redefining them, I finally got it to work. Still having trouble aligning walls but am working on it. Thanks David. Link to comment Share on other sites More sharing options...
