GeneDavis Posted September 11, 2016 Share Posted September 11, 2016 I have checked the box for boxed eaves and this is all the box I get. I unchecked to remove, then checked, same story. What am I doing wrong? Link to comment Share on other sites More sharing options...
country Posted September 11, 2016 Share Posted September 11, 2016 Where is your roof baseline? If it is outside the perimeter wall, the eaves will only box to it. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 11, 2016 Author Share Posted September 11, 2016 No, that isn't it, but thanks. Here's the plan. The roofs that won't box are the two main 12:12 planes. The gable overhangs are done as separate planes because they do not get the boxed detail. Edit: my problem has been solved. Not sure why it was solved, but all is OK with the eaves. Edit 2: no, the problem is not solved. The archived file was OK, but the one I have zipped and is here has the problem. Edit 3: forced a fix by unchecking "default to overhang" and entering 24" in the distance box. Cabin 2 bed 2 bath.zip Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 11, 2016 Share Posted September 11, 2016 here is the issue. Afer doing this they fill in. 1 Link to comment Share on other sites More sharing options...
winterdd Posted 22 hours ago Share Posted 22 hours ago On 9/11/2016 at 12:00 PM, DRAWZILLA said: here is the issue. Afer doing this they fill in. 10 years later and this really help my situation today. 1 Link to comment Share on other sites More sharing options...
