3D display problem
djhplanning
Go to solution Solved by Gawdzira,
Or your video card just sucks, you might want to update your video card drivers to see if that helps or adjust as Alan said your origin in Camera defaults. If your video hardware is integrated into the mother board then it is a certainty that you need to obtain and install a dedicated video card.
Somehow the scale in my template drawing got way out of wack.  I ended up fixing by turning on all layers, window, fill window, erasing a terrain perimeter I had set up in my default drawing, and zooming in to a proper scale when drawing the first wall.  I think I was drawing my first wall very far away from the terrain perimeter I had set up.  Thank you for the suggestions!!!
