basilbabaa
Explode Sketchup Symbols?
Yes this can be done in Chief but you will find it quite challenging simply because of the number of surfaces in this particular file. What component would you like to isolate?
 Have to run now here is some reading.
https://chieftalk.chiefarchitect.com/index.php?/topic/8375-editing-3d-warehouse-objects/
https://chieftalk.chiefarchitect.com/index.php?/topic/9483-how-to-explode-or-ungroup-imported-skp-models/
I think the difference is that you can't "explode" the objects while keeping sub-component integrity, but you can explode the surfaces.
You should separate what you want in Sketchup and export/import your "objects" individually.
You can explode in SU and save a selected "component" from SU to wherever you want to put it.  Componets are a group of
surfaces (usually a symbol or part of one).  Or you can delete everything you don't want in the main SU file do a save as and then
reopen the original file and do the same for another item.
I looked at the SU file and some of those items are individual items but not components.  Simply select an item, right click and select
make component and then you can select and right click again and save the component.
  The ones that are already components you will get a save as option.  After saving you can then importinto Chief.
    27478
    Oilersfan20
    Oilersfan20
