Rounded Wall Corner
Rich_Winsor
Seems easy enough but I haven't been able to make it happen.
I don't need a curved wall. I need a curved corner on the 90°
intersection of 2 straight walls. I can achieve the effect using a
molding polyline but then it doesn't behave as a wall. I tried a
vertical quarter round molding at the intersection but the walls
snap together at the corner and override the molding section.
Any thoughts?
Hi Scott,  Yes three walls with the radius created by a "Curved Exterior Wall"  post-4797-0-49374100-1471661230.jpg  cranked around as tight as it will go to form a 90corner. Not too difficult. I take that back as Chief just locked up on me after posting.  Tech will be really happy to hear from me again.
Chopsaw
Yeah, I had a play with the three wall approach. The catch is
that you can't get a tight enough radius unless you use a very
thin wall. This, of course, leads directly to the 5 wall approach.
BTW, for some reason that curved wall section really slows
down my machine too. Didn't crash it though.
Rich,  I was able to get a sharp inside 90 with a  6" wall after I posted the first pic. I you want to look at the plan I can post for you. It is just a matter of finding the correct handle.  And Oh I think I crashed because I had 2 plans open and the other had already maxed out my video card.
