How to turn off "Text Line with Arrow" ?
ajrare
Often will use “Text Line with Arrow” to point from “Callouts” to a specific location.   On some Layouts I do not want to show “Callouts”.   When I turn off Callouts under “Display Options” I have not figured out to not show the arrows that point from the Callouts.    Is there a simple way to turn off the arrows from the Callouts?
If you're just using the OOB settings, those arrows are probably on the "Text" layer.  You can very easily figure out what layer they are on by opening the line, clicking on the Line Style tab and then checking the layer, or even quicker...once the line is selected, click on the little Object Layer Properties button (looks like a little square with an "O" in it), or even quicker than that...if your Active Layer Display Options window is open, simply selecting the object should isolate and highlight the item's layer(s) so you can then turn it off if you'd like.
