Griffin Posted June 29, 2016 Share Posted June 29, 2016 I can add wainscoting from the library, but it does not seem to have a Room Finish Schedule entry. It does not appear under any to the currently defined columns (wall covering, chair rail, etc.) Do I need to export my schedule to Excel, add this manually, and then bring it back in as a PDF - what am I missing??? Link to comment Share on other sites More sharing options...
Griffin Posted June 29, 2016 Author Share Posted June 29, 2016 I guess I can convert the schedule to text and add it manually too.. Link to comment Share on other sites More sharing options...
MarkMc Posted June 29, 2016 Share Posted June 29, 2016 It ends up in the cabinet schedule and I don't see a way to get it into the Room Finish schedule. Can't add sub category to that schedule and blocking an item doesn't offer the option to get it there either. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 29, 2016 Share Posted June 29, 2016 If you use a Wall Material Region it will show up in the materials list but not in the finish schedule. Probably the best solution would be to use a "Wall Covering". That will show up in the Room Schedule. You can rename the Column "Wainscot". Link to comment Share on other sites More sharing options...
