Canuck Posted June 20, 2016 Share Posted June 20, 2016 I've noted that when you use a half wall, the wall hatching/fill is linked to a full 2x4 wall. Is there a way to separate the link so that a Half wall is seen with a different hatching/fill on the plan? Link to comment Share on other sites More sharing options...
javatom Posted June 20, 2016 Share Posted June 20, 2016 You could create a new wall type that has a different looking fill pattern as determined in the wall definition. Link to comment Share on other sites More sharing options...
Solution justmejerry Posted June 20, 2016 Solution Share Posted June 20, 2016 Richard just create a wall type and select whichever fill you would like. Link to comment Share on other sites More sharing options...
Canuck Posted June 20, 2016 Author Share Posted June 20, 2016 Well, I tried that before and it didn't work. I ended up with all my interior 2x4 walls changing the fill/hatching. With that said, I just did it again and it worked fine....Gremlins..... Link to comment Share on other sites More sharing options...
