SNestor Posted June 17, 2016 Share Posted June 17, 2016 I was attempting to create a vanity as per the instructions in the CA Knowledge Base. So...it's a single vanity and you use the DBX tools to divide it into sections etc. Fairly basic. When I went to add the sink...I couldn't center it because each end cabinet is not a separate section. Also, I am only allowed to install one sink into this unit. So...to create a vanity cabinet that looks like the attached...do I really need to use separate cabinets and join them together? The picture shown in the knowledge base topic shows two bowls...so, I would guess there is a way to do this that I don't know about? Thanks. Link to comment Share on other sites More sharing options...
MarkMc Posted June 17, 2016 Share Posted June 17, 2016 and to center the sink temporarily drop a cabinet of the correct size in front and aligned to the side- or better yet float both sinks- first float one sink, center to temporary cabinet- copy and paste in place both- reflect about the large vanity- then select the sinks and center front to back on the large vanity. Delete temporary cabinets. If you have keyboard shortcuts set for copy and paste in place, and reflect about object it is really fast. Link to comment Share on other sites More sharing options...
