Adam_Gibson Posted June 6, 2016 Share Posted June 6, 2016 I thought I'd share this discovery. Since I design a lot of kitchens and often use soffits, floating or otherwise, to compress spaces, I've always had issues placing recessed lights in custom soffits, e.g.: polyline solids that I've designated as soffits. The recessed cans always conform to the pitch of the roof in a vaulted (cathedral) ceiling, which looks terrible in a rendering, and bizarre in elevation. Chief is smart enough to place cans properly when using cabinet soffits, but not in polyline solids for good reason. If you add a custom ceiling plane at the same height as the bottom of the soffit with zero pitch, the recessed cans conform to that pitch. You can then turn off the ceiling plane layers in any views since you won't need to see them. Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted June 6, 2016 Share Posted June 6, 2016 Good to know, Adam, Thanks for this! Link to comment Share on other sites More sharing options...
Dermot Posted June 6, 2016 Share Posted June 6, 2016 You can also turn off "Flush Mounted" on the Options panel in the Symbol Specification dialog (use Open Symbol and not Open Object). Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 6, 2016 Share Posted June 6, 2016 You can also change the fixture to mount based upon floor height versus the ceiling. Graham Link to comment Share on other sites More sharing options...
Adam_Gibson Posted June 7, 2016 Author Share Posted June 7, 2016 Thanks for the responses! Link to comment Share on other sites More sharing options...
