Don_Straub_Const Posted June 3, 2016 Share Posted June 3, 2016 I inserted this sink form the library but there is no hole. If I lower it more I have the hardware sticking out like it is in quick sand. How do you manually cut a hole for a sink. Attached picture and file gsantos.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 3, 2016 Share Posted June 3, 2016 Its not cutting a hole in your countertop because your countertop is not a countertop at all, its a FIXTURE (or symbol). Try using a custom countertop instead of that fixture and it works fine. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted June 3, 2016 Share Posted June 3, 2016 What Mike said. Here is a fix just make the adjustments you need. gsantos counter.plan Link to comment Share on other sites More sharing options...
