Why does "undo" change my annoset?
johnny
Johnny,
As far as I know Chief will change both the Annoset and Layerset as you undo.
The Annoset and Layerset will change to match the ones that were present when the object was drawn.
This helps, for example, when you have drawn objects and then changed layersets so that some objects are now on a hidden layer.
As you undo, the layerset is changed so that the objects now become visible before they undo.
Makes perfect sense to me - Chief takes you back to the same state as when the object was drawn.
http://screencast.com/t/fsMTTskq
