Member Statistics
Similar Content
By No1ZZTopfan
Look very close and tell me if you can find the hidden bi-fold door. I'll post where its at in a few days. :-)
By nikiley
Hi All!
I am wondering if there is a way to add hardware to a window like sash locks or casement cranks. I did not see any options in the window specification dialog, but I wonder if I could create something to apply in the treatment tab that would work. Has anyone here experimented with something like that?
By TKInteriors
Hi there,
I created a custom molding using polylines then created "Molding" symbol.
It wraps fine on the inside corners but doesn't connect at the outside corner.
See attached. And thanks in advance for the help.
Kind regards, Tamela
By stevenyhof
I have downloaded the three garage door catalogs from the Library, and non of them have a standard wide paneled garage door. They also do not have a wide paneled 8' high door (5 panels high)
What they have is 5 panel high flush doors - so this can be stretched - cool
But there are no standard paneled, wide (16' and 18') 4 or 5 high garage doors.
Does someone have access to such doors?
The long panel door comes in both 4 panel wide and 2 panel wide - very good.
The door with the 4 panels across come should also come with 8 panels for wider doors.
Am I missing it somewhere? It's like the most common door used from Menards and Lowes. Starter doors.
Thank you
By elijahkay
Is there a currently available way to apply a separate color and line type to the swing of the Swinging Door object?
