Sign in to follow this
WhistlerBuilder
Dimensions off in Elevation
I am having a strange issue trying to dimension window sill heights in an elevation view. The heights are correct on the first floor, but the second floor mysteriously is adding 3/8" extra to the dimension. I have checked my baseline elevations and checked the window height in multiple sections and elevations and floor plans, the height is consistent across the plans but it is displaying an extra 3/8" in the elevation view.
Any suggestions?
See elevation 2, top right window on 2nd floor. Sill height should be 2' but it is displayed as 2' 3/8". I seem to encounter this issue often.
Spruce st House 6.plan
Your top 2 elevation lines each appear to be 3/8" too low.  Fix that and you should be good to go.
As Michael said your elevation dimension lines are off. Your second floor is also off exactly 3/8" from the default for the floor. your default shows 97 1/8" and your rooms are showing 96 3/4". Not sure how you guys in B.C. mark your elevations but we usually show the head height here. You could use the auto story pole dimensions and do all that. I am wondering how you are going to get any lintels above those windows if you have them at 96" to top. especially the 11' mulled unit.
Thanks for the heads up. I do not understand how, but the rough ceiling height had auto changed on me for some reason. It used to be 108 3/4", so there is my missing dimension.
Cheers,
Is there a way to change the default wall height? It seems to be set to 97 1/8" even after I have changed all the rooms to 96 3/4" Some windows are displaying at the proper height while others are not even on rooms that have the same floor height. This is very confusing that it would show some windows at the proper height while others are not within the same room.
Yes there is. Go to the floor you want to affect and then go to Edit>Default Settings>Floor and change it there.
And BTW, thank you for posting the plan without being asked. You get a gold star (and a point) for that.
    28897
    tmactom
    tmactom
  • Similar Content
    • By Ange822
      I am using Chief Architect Premier X9
      My defaults seemed to have changed so that when I select a window - it is now showing temporary dimensions of the window casing / center of window / trim. (see attached screen shots)
      How do I change this to only show the window opening to wall stud?
      thanks in advanced!
      Angela
    • By ericepv
      Rochester, NY based rendering company available for remote work. I am a long time Chief user (currently on X-12 but equipped with earlier versions also) and have worked for many commercial and residential clients across the country. You can view samples of my work on my website https://epvisualz.com .
      Please contact me directly at 585-441-5291 or by email: eric@epvisualz.com .
    • By Designer100
      Hi,
           I am trying to place columns and grid line with dimensions.
      I have to create on column circles and columns lines , then the dimensions will not place correctly to center usining manunel dimensinos (its leaves 12in on each side of column center lines.
      Chief Architect needs to be more friendly and have more commercial symbols and column lines to dimensions to them. They do have a commercial templet, but it does not have any of those.
      Plus they need commercial window details etc. I am donating this for a non-profit to design a rendering and another area added on the back of this building.I am donating a rendering of exterior to help them fund raise $300.000.00 (by December) to buy the exist. building and remodel adding finishes to look better and another 2,000 s.f. to it.
      Can anyone help me on working out the Grid center lines and will measuring correctly? turn on background and existing bldg. is under neath.
      Thanks,
      Newell
      CA Premier x 12
      Porter Road Floor Plan existing.PDF
      Existing Building remodeling.Addition.plan
    • By steve_mcdowell
      Looking for design partner for upcoming projects. My previous designer used Chief and he is too busy to take on additional work. Ideally looking for someone who may have building experience in addition to being a designer. Looking for someone who can deliver preliminary floor plans and elevations to facilitate proof of concept, someone who can design to specific standards for ARC review and submission standards. The designer will need to understand page naming conventions and all related requirements for the city of Bend Oregon for streamlined permit submission. Structural drafting and coordination with structural engineers.
      See attached files as example of the type of drawings needed
      A0.01 COVER SHEET.pdf
      A0.02 PLAN NOTES.pdf
      A1.01 SITE PLAN.pdf
      A1.02 MAIN FLOOR PLAN.pdf
      A1.03 LOWER FLOOR PLAN.pdf
      A1.04 FOUNDATION AND LOWER FLOOR FRAMING.pdf
      A1.05 LOWER ROOF AND UPPER FLOOR FRAMING.pdf
      A1.06 UPPER ROOF FRAMING.pdf
      A2.01 EXTERIOR ELEVATIONS.pdf
      A2.02 EXTERIOR ELEVATIONS.pdf
      A3.01 BUILDING SECTIONS.pdf
    • By sascea
      Does anyone know how to change the decimal under the story pole marker lines? I've attached a picture, it's the numbers circled in orange. I would like to get rid of them completely as some of my story pole markers are close together and this takes up extra space.
      Thank you in advance!!
