mountaineer Posted April 15, 2016 Share Posted April 15, 2016 I'm struggling with how to connect room walls to my shed dormer walls. I don't know if I need to change wall type? Any input is greatly appreciated. I'm a rookie user still navigating my way through. I've attached the plan I'm working on. I know there are a lot of things that need corrected on this plan but so far I'm stuck on the second floor. Chief Shed Dormer Problem.plan Link to comment Share on other sites More sharing options...
javatom Posted April 15, 2016 Share Posted April 15, 2016 I have not opened the plan but sometimes you need to explode the dormer so you have more control of it. Auto dormer only gets you so far. Link to comment Share on other sites More sharing options...
mountaineer Posted April 15, 2016 Author Share Posted April 15, 2016 Thanks Javatom, I'll play with that. I've also notice that when I connect my porch roof that my dormer disappears. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 15, 2016 Share Posted April 15, 2016 I looked at your plan file and what happens is when you attach the shed roof, it destroys the dormer, so like Javatom said, the solution is to explode the dormer and then manually attach the shed roof around the edges of the dormer. A default dormer object is not programmed to cross two roof planes, you have to manually shape the roof plane edges to allow the dormer to stay. DJP Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted April 15, 2016 Solution Share Posted April 15, 2016 Here is a You Tube video of me working on your plan: https://youtu.be/FZ9fJc2khSI DJP Link to comment Share on other sites More sharing options...
mountaineer Posted April 18, 2016 Author Share Posted April 18, 2016 Wow David! Thank you so much for the video. It's refreshing to watch you work through these issues. Reminds me to stay patient and persistent when learning Chief! Link to comment Share on other sites More sharing options...
