myrtsbnye Posted April 14, 2016 Share Posted April 14, 2016 Is there a way to make a circular hole in the ceiling? My client would like a domed feature in the entryway ceiling but I can't seem to figure out a way to place a circular hole in the ceiling. Thanks Link to comment Share on other sites More sharing options...
javatom Posted April 14, 2016 Share Posted April 14, 2016 Make 2 copies of the circle. You can use them for molding lines that will follow the circle. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 14, 2016 Share Posted April 14, 2016 I have done this using different geometric objects like Eric points out (octogon, hexagon, circle, rectangle) which you can then make to look like a raised area by capping the "hole". How complicated or sophisticated is up to you, your client and your willingness and patience. You use the available 3D modeling tools to model the effect a step at a time. DJP Link to comment Share on other sites More sharing options...
myrtsbnye Posted April 19, 2016 Author Share Posted April 19, 2016 Thanks fellows, that did it. Link to comment Share on other sites More sharing options...
