eaves align wt truss
natmar
You use the "Raise off Plate" input box before building roofs (the truss tool merely fills the void created between ceilings and the underside of roofs), so you prepare the space when you build roofs and then draw manually the trusses. Such trusses are often referred to as "Energy Heel Trusses".
