TSJDesign Posted April 1, 2016 Share Posted April 1, 2016 I am a complete macro dunce, so please forgive if this is a elementary question. I would like to make a seemingly simple modification to a "user" macro that ships with x8 - FormattedOpeningWidth. All I want to do is add a "/" character between the foot and inch results (currently a 3'-6" opening gives a result of 36. I would like to see 3/6) I looked at the macro and realized I haven't a clue, so I'm hoping someone here can provide the magic syntax to make this happen. Thank you! Todd Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 1, 2016 Share Posted April 1, 2016 Todd, Copy/Paste the following as a replacement for the existing: arr = width.round.divmod(12) arr = "#{arr[0]}#{arr[1].round}" arr = arr[0]+"/" + arr[1] Or create a new macro with that code. Characters in a string are numbered 0,1,2,3,4,5...... So arr[0] is the first character, arr[1] is the second, etc. The 3rd line just puts a (slash) between those 2. Link to comment Share on other sites More sharing options...
TSJDesign Posted April 1, 2016 Author Share Posted April 1, 2016 Joe - thank you so much, worked perfectly! Your explanation is helpful, although macros in their entirety are absolutely baffling to me. I'm usually pretty good at reverse engineering things, but without even the basic knowledge of syntax, I would not know where to start. Thank you so much for your help - my client will be happy! Todd Link to comment Share on other sites More sharing options...
BrownTiger Posted April 1, 2016 Share Posted April 1, 2016 >Characters in a string are numbered 0,1,2,3,4,5...... Techncally these are not "characters", it is an array. ...and divmod produces array of a quotient and modulus. There are typed as Float's. See http://ruby-doc.org/core-2.3.0/Numeric.html#method-i-divmod One can also do a,b = width.round.divmod(12) I recommend you to create your own extended class Float and save it into 'FloatExtended.rb' under Documents\ChiefArchitect v8\scripts. This will allow You instead of putting dreaded logic in every macro to use include file... require 'FloatExtended.rb' //after that you couldimmediately use... width.to_ftin(16) //instead of a giant macro you now can use one liner Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 1, 2016 Share Posted April 1, 2016 >Characters in a string are numbered 0,1,2,3,4,5...... Techncally these are not "characters", it is an array. ...and divmod produces array of a quotient and modulus. There are typed as Float's. Technically you are correct. But for the amateurs it's sometimes simpler to show a sequence of commands rather than the most elegant programming syntax. Also, you didn't show the definition of to_ftin that would be needed to put the slash in. I've found that most Chief users (at least on the forum) are very reluctant to learn Ruby. Link to comment Share on other sites More sharing options...
BrownTiger Posted April 1, 2016 Share Posted April 1, 2016 Here is my class FloatExtended.rb to be placed into C:\Users\<name>\Documents\Chief Architect Premier X# Data\Scripts class Float def to_ftin(n=16) arr = self.divmod(12) inch_frac = ((arr[1]-arr[1].floor)*n).round.quo(n) result = case inch_frac when Rational(1.0) "#{arr[0]}'-#{arr[1].ceil}\"" when Rational(0.0) "#{arr[0]}'-#{arr[1].floor}\"" else "#{arr[0].floor}'-#{arr[1].floor} #{inch_frac}\"" end result end def to_inches(n=8) inch_frac = ((self-self.floor)*n).round.quo(n) result = case inch_frac when Rational(1.0) "#{self.ceil}\"" when Rational(0.0) "#{self.floor}\"" else "#{self.floor} #{inch_frac}\"" end result end end Using it is very simple, this macro would be two liner. require "FloatExtended.rb" width.to_ftin or 209.to_ftin For your case the line "#{self.floor} #{inch_frac}\"" needs to be changed into "#{self.floor}" + "/" + "#{inch_frac}\"" Link to comment Share on other sites More sharing options...
BrownTiger Posted April 2, 2016 Share Posted April 2, 2016 def to_full_inches self.round end def to_full_ftin arr = self.round(0).divmod(12) "#{arr[0]}'-#{arr[1].round}\"" end Last two methods to complete the class. So that entire ceiling_height: require "FloatExtended.rb" (ceiling_elevation-floor_elevation).to_full_ftin + " CLG.HT." Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 2, 2016 Share Posted April 2, 2016 def to_full_inches self.round end def to_full_ftin arr = self.round(0).divmod(12) "#{arr[0]}'-#{arr[1].round}\"" end Last two methods to complete the class. So that entire ceiling_height: require "FloatExtended.rb" (ceiling_elevation-floor_elevation).to_full_ftin + " CLG.HT." FWIW, I already have a FloatClass.rb with similar but mine does Metric as well. Link to comment Share on other sites More sharing options...
TSJDesign Posted May 4, 2016 Author Share Posted May 4, 2016 Hey there - So I just noticed that the method from the top of the post does not appear deal with openings with components that are not single numbers (for instance a 2'-10" door show as 2/1, and a 12'-6" opening shows up as 1/2). There was discussion after that post, but unfortunately it was (far) over my head. Any ideas? Link to comment Share on other sites More sharing options...
BrownTiger Posted May 5, 2016 Share Posted May 5, 2016 Todd, take a look at a code I posted, specifically to_ftin. Replace - with /. Or use the full class I supplied. E.g. width.to_ftin... B Link to comment Share on other sites More sharing options...
