Griffin Posted March 23, 2016 Share Posted March 23, 2016 New to CA, and love it so far. That is except for the default Chief Blueprint font as I greatly prefer Graphite Standard. I've reset my text styles in Preferences three times, but it seems that every time I start a new file it defaults back to Blueprint. What am I missing, or do I need to rename my fonts in Windows with a bit editor. Thanks. Link to comment Share on other sites More sharing options...
chief58 Posted March 23, 2016 Share Posted March 23, 2016 If you are using annotation sets you might have to change the text in there Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 23, 2016 Share Posted March 23, 2016 The correct procedure is to open "Chief Architect X8 Data - Templates - profile.plan (for imperial units) or profilem.plan (metric units)" and make your font changes via Default Settings and the various categories extant in the annotation sets. Once you get it exactly the way you want then you save-as over the existing profile.plan with your customized one and when you then order "New Plan" a copy of your customized profile.plan will then present itself. The same is true for the layout templates in that you can customize those templates to fit your needs and then select the size you need and it will be there if you create it and then select it. DJP 1 Link to comment Share on other sites More sharing options...
Griffin Posted March 26, 2016 Author Share Posted March 26, 2016 Thank you both for the response. DJP you rock! Link to comment Share on other sites More sharing options...
