mydog8it Posted March 12, 2016 Share Posted March 12, 2016 Has anyone found a way to edit the shadow intensity for an existing/saved vector elevation? I changed the defaults under camera > rendering techniques, but that only seems to apply to new cameras. I'm not seeing an option to edit the shadows under 3d > edit active camera, just to turn them on and off. Sidenote: The elevation shadows look amazing! Well done, CA. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 12, 2016 Share Posted March 12, 2016 Has anyone found a way to edit the shadow intensity for an existing/saved vector elevation? I changed the defaults under camera > rendering techniques, but that only seems to apply to new cameras. I'm not seeing an option to edit the shadows under 3d > edit active camera, just to turn them on and off. Sidenote: The elevation shadows look amazing! Well done, CA. Maybe I'm not understanding, but if you open that camera view and just either double click the little vector view icon or open the Rendering Technique Options dbx, you should be able to just adjust the shadow intensity there. Link to comment Share on other sites More sharing options...
mydog8it Posted March 12, 2016 Author Share Posted March 12, 2016 Maybe I'm not understanding, but if you open that camera view and just either double click the little vector view icon or open the Rendering Technique Options dbx, you should be able to just adjust the shadow intensity there. Thank you. 'Technique Options' did the trick. I knew it had to be something ridiculously simple. Link to comment Share on other sites More sharing options...
BennyD Posted March 19, 2016 Share Posted March 19, 2016 Whew, this one threw me off as well. All the options under adjust sunlight had an effect on the shadows, like angles and tilt, but not the sun intensity. Link to comment Share on other sites More sharing options...
