Migaloo Posted February 23, 2016 Share Posted February 23, 2016 I can't figure out what is making this band around this room. The floor is sunken 12" from rest of house. No moldings are turned on. Can't select the line individually but you can use the eyedropper to change the material finish. Any thoughts? Link to comment Share on other sites More sharing options...
Rosco2017 Posted February 23, 2016 Share Posted February 23, 2016 Can you post the plan? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 24, 2016 Share Posted February 24, 2016 yep post it. Does the band sit on the exterior surface and not intrude into the wall? Link to comment Share on other sites More sharing options...
Rosco2017 Posted February 24, 2016 Share Posted February 24, 2016 Check and see if you have a wall covering applied to that room. That's how I'm able to replicate your issue... If that's not your issue, please post the plan for more accurate help... Link to comment Share on other sites More sharing options...
Rosco2017 Posted February 24, 2016 Share Posted February 24, 2016 http://www.screencast.com/t/ZKZr5gNBct1I That's how to get rid of it if it's a wall material you assigned in the room specification dialogue box. Link to comment Share on other sites More sharing options...
Migaloo Posted February 24, 2016 Author Share Posted February 24, 2016 Thank you rosco2017. Not sure how it got assigned to that room specifically but that's what the issue was. Link to comment Share on other sites More sharing options...
