MigP74 Posted February 8, 2016 Share Posted February 8, 2016 I have created a staircase going from the 1st floor to the 2nd. All seems to line up correctly, but when on the 2nd floor, the stairs do not appear even though the room type has sucessfully changed to Open Below. Thanks in advance for the help. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 8, 2016 Share Posted February 8, 2016 there is a setting for that. 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 8, 2016 Author Share Posted February 8, 2016 Thank you for the quick reply. I don't have that option however. I am using X2, but it worked fine before I must have done something wrong. Link to comment Share on other sites More sharing options...
MigP74 Posted February 11, 2016 Author Share Posted February 11, 2016 I have tried creating a whole new plan for testing, and every staircase I make is not visible on the upper floor. Even if I just create a solid that should go through to the upper floor, and have the upper floor as "Open below", the same happens. Only a white space appears. So my guess is the plan doesn't necessarily contain errors; there must be an option I am overlooking. I am still at a loss here though. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Solution Dermot Posted February 11, 2016 Solution Share Posted February 11, 2016 Are you using a floor camera or a full camera? In X2, floor cameras will not show anything above or below the floor you are on. In X7, floor cameras have the option of showing the floors below them (as shown by Perry in his post). Full cameras will always show the whole model (except what is hidden through layers). 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 11, 2016 Author Share Posted February 11, 2016 I was using the perspective floor overview, but with full camera I can see it .But I've used the perspective floor overview before and it used to show it too, but now it doesn't. Link to comment Share on other sites More sharing options...
