TheKitchenAbode Posted February 7, 2016 Share Posted February 7, 2016 Just ran into something. If for say you alter the height of a chandelier the lights offset position from it's base does not change accordingly, it stays at the default offset position. You must manually change this it to relocate the light position properly within the fixture. Graham Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 7, 2016 Share Posted February 7, 2016 Sounds like a "suggestion" to me or perhaps a feature request or bug fix, the lights should follow end user adjustments of the fixture. DJP Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 8, 2016 Author Share Posted February 8, 2016 Thanks David - Just posted this under "Suggestions" Graham Link to comment Share on other sites More sharing options...
