Rashid_Garuba Posted February 3, 2016 Share Posted February 3, 2016 This is likely a "duh, you must be over 50" and forgot" moment. On a daily basis while working on floor plans the Rooms select way too often and gets in my way.. Ideally a triple select to select Room will be great. Once the structure is established, I rarely need to select rooms... A setting somewhere? Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted February 3, 2016 Author Share Posted February 3, 2016 Rashid... You can try locking the Room layer.. Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted February 3, 2016 Author Share Posted February 3, 2016 That works I guess... Going senile.. found the answer 3 minutes after starting the topic. Anyone with a better idea please chime in. Link to comment Share on other sites More sharing options...
dshall Posted February 3, 2016 Share Posted February 3, 2016 Uncheck select room before wall in 3d 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted February 3, 2016 Share Posted February 3, 2016 This is what I love about the Active Layer Display Options thingy ma bob. I always have that tool open and set to ----> This will pop the selected objects layer to the front of my list and then I can quickly lock that puppy out so I don't keep making the same mistake and expecting different results (which happens to be the clearest definition for insanity). Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted February 3, 2016 Author Share Posted February 3, 2016 Scott.. I do have that unchecked but only helps in 3D, not 2D.. Alan.. Yes I have it open all the time but just discovered you can add the lock column to the ALDO!.. Link to comment Share on other sites More sharing options...
