GLOBE-Res Posted January 29, 2016 Share Posted January 29, 2016 Hi folks, At the office I'm working in presently we have CAx7. But at home office I still have 9.5. I'm having trouble setting up my printer preferences in this older version. Can anyone help me walk thru getting my printer set up with this group? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 29, 2016 Share Posted January 29, 2016 I have 9.5 on my XP hard drive but honestly, I have not used it especially for printing. I am sure I could get to print if I needed to. As I recall, you must set your printer up in Windows first and then with it pre selected and set up in Windows you should then be able to print from Chief 9.5, so the main thing is set up Windows, format for the paper size and orientation in Windows first and then make those same adjustments in Chief 9.5. DJP Link to comment Share on other sites More sharing options...
GLOBE-Res Posted January 29, 2016 Author Share Posted January 29, 2016 Thanks Dave! Looks like I'm not the only one burning the evening oil. I was able to get my printing to work. This version is really due for an update. The version I am using at my client's office, x7, is really so much better. Looks like I need to bite the bullet and upgrade. Thanks again! Link to comment Share on other sites More sharing options...
lbuttery Posted January 29, 2016 Share Posted January 29, 2016 another choice is to use PDF995 which came on the Chief disc's back then print to PDF995 and then print to the printer Lew Link to comment Share on other sites More sharing options...
