agenoarch Posted January 28, 2016 Share Posted January 28, 2016 I'm not sure if I'm missing something but I'm trying to achieve a railing for an ADA ramp with all round profiles for spindles, rail, and raised bottom rail and the DBX box does not have a selection to do this for the bottom rail. Am I missing something. Thanks Sal Link to comment Share on other sites More sharing options...
rlackore Posted January 28, 2016 Share Posted January 28, 2016 See the picture. Select the Bottom Rail from the drop-down and Replace the profile with a round section. Link to comment Share on other sites More sharing options...
agenoarch Posted February 1, 2016 Author Share Posted February 1, 2016 Thanks Robert but I am trying to change this specifically on a ramp bottom rail and I do not see the drop down option. Do you see this also? Link to comment Share on other sites More sharing options...
glennw Posted February 1, 2016 Share Posted February 1, 2016 Sal, You will need to turn off the rail that comes with the ramp and use a railing wall with "Follow Stairs" checked. You then have access to the bottom rail setting. Link to comment Share on other sites More sharing options...
agenoarch Posted February 2, 2016 Author Share Posted February 2, 2016 That works-Thanks But maybe a suggestion is to have the ability to change it in the ramp DBX instead of the wall(railing) on top of a ramp idea Link to comment Share on other sites More sharing options...
