Designer100 Posted January 14, 2016 Share Posted January 14, 2016 Can anyone help to get the circle wall on back side of stair and closed under stair. Need 2 2'8" or 3' doors cleared going to verada. Might even consider w.i. railings. balcony railing on stair is not matching stair railding. rear 2nd floor rear balcony need beams below it and maybe w.i. railings. Walker.Patrick 1.plan Link to comment Share on other sites More sharing options...
glennw Posted January 14, 2016 Share Posted January 14, 2016 I won't do it for you, but I can give you a tip on how to do it. Make sure your stair is correct. Toggle on View..."Arc Centres and Ends". In the wall dbx, make sure General...Curved Wall...Lock, is checked (it already should be). Snap the wall centre onto the stair centre and then drag the wall to suit. Link to comment Share on other sites More sharing options...
yusuf-333 Posted January 18, 2016 Share Posted January 18, 2016 Can anyone help to get the circle wall on back side of stair and closed under stair. Need 2 2'8" or 3' doors cleared going to verada. Might even consider w.i. railings. balcony railing on stair is not matching stair railding. rear 2nd floor rear balcony need beams below it and maybe w.i. railings. W.I railings on your stair, I am not sure if that is what you wanted. Here it is, if it helps. Walker.Patrick st 1 1.zip Link to comment Share on other sites More sharing options...
