HumbleChief Posted January 12, 2016 Share Posted January 12, 2016 I've exported ACAD successfully in the past but must have changed a setting somewhere and am getting this black filled wall output. or at least the other (not very good) user with ACAD is getting this result. You can see the cabinets and fixtures are filled black as well. Is there an export setting I should use to avoid this? ACAD OUTPUT BLACK.pdf Link to comment Share on other sites More sharing options...
glennw Posted January 12, 2016 Share Posted January 12, 2016 Larry, I don't know, but have you tried unchecking "Export Filled Areas"? Link to comment Share on other sites More sharing options...
HumbleChief Posted January 12, 2016 Author Share Posted January 12, 2016 I'll try it Glenn, Thanks Link to comment Share on other sites More sharing options...
