tahoebrian5 Posted December 9, 2015 Share Posted December 9, 2015 I've found how to change transparency for hatch/fill but what about lines, either cad or part of objects? For example I like to shade back my electrical symbols if I include them on my main floor plan instead of a dedicated electrical plan. Another case is showing demo walls shaded back and dashed. I would much rather do this than try to find greyscale colors that look similar. It would be great if you could set transparency by layer but does not appear to be the case. Link to comment Share on other sites More sharing options...
tahoebrian5 Posted December 9, 2015 Author Share Posted December 9, 2015 Another line question.. Is there a setting similar to autocad LTScale? Or do you have to define new line types to get a different line style spacing? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 10, 2015 Share Posted December 10, 2015 Brian, You can change the LineStyle, Color, LineWeight and Text Style on a per Layer Set basis. IOW, the same Layer can have different display parameters in different LayerSets. Then, if you also use Annosets, you can specify the defaults for Dimensions, Text, Rich Text, Callouts, Markers, Arrows, the current CAD Layer and even the desired Layer Set. Link to comment Share on other sites More sharing options...
tahoebrian5 Posted December 10, 2015 Author Share Posted December 10, 2015 Yes, but what about line type scale and transparency? I haven't been able to find settings for these, other than fill style transparency. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 10, 2015 Share Posted December 10, 2015 Those don't exist in Chief. You just have to adjust by using different line styles and colors of gray. Link to comment Share on other sites More sharing options...
glennw Posted December 10, 2015 Share Posted December 10, 2015 For lines, there is also the Drawing Group which may help with what you are trying to achieve. Link to comment Share on other sites More sharing options...
