Raytrace Settings...
Designer1
Does anyone know if Chief can save a specific raytrace setting?  For instance, I know you can save a setting per each plan but can you have lets say two settings, one for exteriors and one for interiors and be able to browse and select those settings for each of your raytraces regardless of what plan your working in?
I was thinking about this today, as I was doing a lot of raytraces and it takes so much time adjusting the settings in each plan.
Thanks in advance!
Not aware of that ability either. However in the Raytrace settings DBX there really isn't that much to play with, especially if you have Photon Mapping & Caustics on. Setting these on tends to override or minimize the effect of the settings in the general settings section. Is it the Raytrace settings or the light settings in your plan that you are needing to constantly adjust?
Graham
