Pole Barn carport , Truss issue
Designer100
Chief Architect x7           I am trying to build a pole barn open carport and cannot get the trusses to go into it not rafter material not to be there underneath.  Trusses need to look like the attach sketch from prospective client.
Thanks if anyone can help.
Newell Cheatheam
www.newellsdesigns.com
Katy,Tx
281.392.3034
Matt Pole Barn.plan
pole barn carport look.pdf
Thanks for the help.  Rlackore does it need more trusses being 30ft than the four you showed  4?
If they are steel-plate connected light wood trusses, then yes. Of course, you will also need beams to carry the trusses. And lateral bracing, etc. All I was doing was giving you a solution of how to accomplish the truss profile - nothing more.
